View Full Version : mx3500
bonnie750
04-07-2011, 06:57 PM
Hello out there
I've got a mx3500 throwing POD_1 S jams. only does it when it's hot, after say 50 copies.allow the m/c to cool and it's away again until it is hot. it has the latest reverse pg fitted. i reckon it's the POD sensor breaking down when hot. anyone had this fault???
Bill
wtroll
04-07-2011, 08:00 PM
Hello out there
Bill
Hello,
I've already seen this issue, in my case was the POD1 actuator sensor that had difficulty to return to the home position specially when MFP was hot. Clean the actuator and give one more turn to its spring.
Also try to swap POD1 sensor (code: VHPLG248NL1-1) with another identical sensor (like the SHIFTER HOME DETECT sensor).
Regards
hi
besides the sensor problem,if the copier overheats
clean filters and check your fans turning
ta
bonnie750
04-08-2011, 06:51 PM
hello out there
Fixed!!
changed pod_1 sensor test 500 ok
thanks
bill
wtroll
04-08-2011, 07:37 PM
Well, good job!
Have a nice week-end.
