View Full Version : AR-M451N - using the printer without the AR-EF3
vlad_
04-12-2011, 08:09 AM
Good afternoon.
I have AR-M451N without additional options. Only used the printer. Works fine.
Is there a program that allows you to set the machine?
The program "printer status monitor" only gives information about how many paper and toner quantitatively.
Let me add that without the AR-EF3 function "sleep" not working correctly. The device goes into "sleep" and then he wakes up. Disable RG45 - does not help. What you recommend to address these challenges? except for installation of AR-EF3:))
A. Entering the diag mode
With the power OFF, hold and press the [MENU] key and the [OK] key,
and at the same time turn on the power.
B. Selecting diag menus
Press the [MENU] key to change the diag menu.
*Press the [OK] key to execute the test.
*Press [up ] or [down ] key to go to the input menu.
*Press the [BACK/C] key to return to the previous menu
hope that helps
ta
vlad_
04-12-2011, 05:22 PM
hope that helps
ta
I'm sorry, but the copier AR-M451N not find any button:)
lky1978
igi, your method only work for tiger series.
lky1978
04-12-2011, 05:24 PM
vlad,y ur machine not come with ar-ef3?for your situation, i need to try my machine in workshop and then let you know
hi my bad
how abbout via the web browser
ta
vlad_
04-13-2011, 01:58 PM
hi my bad
ta
Through a Web browser?
How to execute the 25-2, 24....... through a Web browser??
ta ???
bilyahn
04-13-2011, 02:06 PM
Can't do it via the web browser. Like lky1978 mentioned this series, the ARM355-451-455 did not start out as a printer like the ARM350 series so it needs the scanner panel to get into diagnostics and system settings. Sorry.
Good luck.
Bil
vlad_
04-13-2011, 02:14 PM
Understood.
Hence, as a printer, AR-M451N/351N will work in the blind.
All thank you very much.
И тебе Игорь.
