View Full Version : Error Code Konica Minolta CF 2002
yiiya69
04-13-2011, 09:45 PM
I have an error code on Konica Minolta CF 2002, code is C-0251.
Machine will not run due to the error code. Any suggestions?
mrwho
04-13-2011, 10:43 PM
I can't find that error - don't you mean C-0521?
Try the trouble reset - With the machine turned on, open the door and, on the right side, under the blue tool, there's a square hole - stick a pen into it and it should reset the code (check the attached pic).
If the error comes back, you have a fuser abnormality - you might need to replace it.
yiiya69
04-13-2011, 10:52 PM
mrwho thank you so very much!!! This worked!!! Thanks again.
mrwho
04-13-2011, 11:05 PM
Glad it worked!
Best way to say "Thanks" is to stick around and help others! ;)
Cheers!
