View Full Version : Sharp Arc-160
Copier Systems
08-01-2007, 04:13 AM
Have call service uo-80 and L8-01 know what code is but what is the fix?
Can fix uo-80 by removing connectors on sub board machine will go into ready.got L8-01 after removing dv units* all connectors were put back whare they were removed from. on u0-80 code-connectors that were removed an pushed back in after ck-ing pins whare connector go.
Help
Andy H.:confused:
blackcat4866
08-22-2007, 01:58 AM
The U0-80 is a communication error between the PCU & the Sub PWB. Sometimes its loose connectors, but more likely you've got fuser oil contaminating the modular plug on the drawer. You can soak the connectors on both sides in Electrokleen, or replace them. Don't worry about the L8-01. That's just dirty power causing that. It will reset. If it keeps coming back you need to address the power issues.
