View Full Version : Ricoh 2090 SC819 Code
mgarretson
08-08-2007, 11:54 PM
I have a Ricoh 2090 with an SC819 error code when I try to update the firmware. I called Tech Support and they said to try the boot rom SD card, that is suposed to rewrite the boot rom. I have since tried a different SD card, 2 hard drives, and I overnighted the Controller ($1836.00) today. It only gives the code when I try to update the Firmware.
Update: I have replaced the Controller, and the code is gone, now it won't read the SD Card at all...:mad:
mgarretson
08-13-2007, 10:14 PM
Turns out my SD card was the problem all the time. I was trying a 1 gb and a 2gb. They were too big for the machine to recognize. the machine will recognize up to 256MB. I finally got a hold of a tech support person that knew what he was doing.
Scott_Lewis
08-14-2007, 03:28 AM
Oops, I've been using a 512mb SD card on my MP7500. So far it seems to have not been a problem when doing a download/upload. Have not tried it for F/W updating. Wonder if the newer machine can recognize the larger memory. I'll just have to get ahold of a smaller SD card.
Thanks for the info.
Tonerbomb
08-14-2007, 01:34 PM
Sorry guy's but all I use is a 1gig card. Works quite well. Try formatting your card with the sd card format app that ricoh recommends.
mgarretson
08-14-2007, 05:25 PM
Tech support said 512MB might work, but he knew the 256 would. Radio Shack had 256MB for $5.99
FRIDGEMAGNET
08-18-2007, 06:45 PM
I have been using a 1GB on all the current models. Only time I had a problem was when I tried it with about 300MB of photos.....OOps.
The copier has to read the complete card and if there is too much on it it can give SC670 or not work at all!
Tonerbomb
08-18-2007, 09:16 PM
Ditto that, I've had firmware for 4 or 5 models on 1 card and found that didn't work. But no problem with the 1 gig.
