View Full Version : Lines all over page on a bizhub c500
Albert
05-10-2011, 09:17 AM
97699768:confused: I need help. I am printing booklets and get lines all over pages specially on pictures.
When print single colors I get lines on yellow and Cyan. I cleaned the Corona wires, the sensors, I switch a developer unit from another machine, switch drums and coronas and didn't help. Please look at the images i uploaded, If you have any sugestions to help isolate this problem please let me know. Cheers.
Zeldaman
05-10-2011, 09:36 AM
Hi there!
I think the Magenta-imaging-unit is gone. You should try another one ( if possible).Make printouts "halftone-pattern" with a value of ca. 125. Then you should see which unit(s) cause the problem.
Greetings...
marlon29
05-10-2011, 10:48 AM
try to replace the hv units that is in contact with the imaging units...maybe this would help
boanda
05-10-2011, 11:13 AM
Replace units or clean corona wires(it easier if u dont have other units) then try to replace PH places to see is there any change on image (eg. exchange cyan and magenta PH)
Zesti
05-10-2011, 11:54 AM
Albert,
Which toner are you using and when did you replaced toner? Also tell me if the toner is scattering around drum and dev. unit especially Magenta.
seeb
05-10-2011, 11:59 AM
I looks like the magenta corona needs to be replaced.
Albert
05-10-2011, 05:02 PM
I will be at the shop laiter on and try yours sugestions, and let you know how this ends, do you guys think is a good idea to change the magenta
Drum potential sensor board.
JustManuals
05-10-2011, 05:07 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
lucky13
05-12-2011, 03:35 AM
what is your PM count on the drums, dev, and coronas to me it looks like bad corona and grid
JSC
05-12-2011, 10:05 AM
Had this type of fault many times, It is always ether carona assy or dev. I would change the carona assy as a whole part 1st.
