View Full Version : Ricoh 1045P - Set FAX baud rate
mmirrotto
05-19-2011, 09:05 PM
Hello! I was hoping someone can assist me with the process to get our Ricoh Aficio 1045P Multifunction to transmit & receive FAX at a lower speed. I am trying to use this over a Vonage link and from what I have read I will need to set the baud to 9600. Any help would be greatly appreciated! I assume I need to get into the FAX SP mode in order to do this since there is not a setting in the general menu for this.
Thanks again
nmfaxman
05-19-2011, 09:49 PM
G3-2 Switch 05 SP No. 1-106-006
No FUNCTION COMMENTS
0
to
3
Initial Tx modem rate
Bit 3 2 1 0 Setting (bps)
0 0 0 1 2.4 k
0 0 1 0 4.8 k
0 0 1 1 7.2 k
0 1 0 0 9.6 k
0 1 0 1 12.0 k
0 1 1 0 14.4 k
0 1 1 1 16.8 k
1 0 0 0 19.2 k
1 0 0 1 21.6 k
1 0 1 0 24.0 k
1 0 1 1 26.4 k
1 1 0 0 28.8 k
1 1 0 1 31.2 k
1 1 1 0 33.6 k
Other settings - Not used
These bits set the initial starting modem rate for
transmission.
Use the dedicated transmission parameters if you
need to change this for specific receivers.
If a modem rate 14.4 kbps or slower is selected, V.8
protocol should be disabled manually.
Cross reference
V.8 protocol on/off - SG3 switch 03, bit2
4
to
5
Initial modem type for 9.6 k or
7.2 kbps.
Bit 5 Bit 4 Setting
0 0 V.29
0 1 V.17
1 0 V.34
1 1 Not used
These bits set the initial modem type for 9.6 and 7.2
kbps, if the initial modem rate is set at these speeds.
6-7 Not used Do not change the settings.
G3-2 Switch 06 SP No. 1-106-007
0
to
3
Initial Rx modem rate
0 0 0 1 2.4 k
0 0 1 0 4.8 k
0 0 1 1 7.2 k
0 1 0 0 9.6 k
0 1 0 1 12.0 k
0 1 1 0 14.4 k
0 1 1 1 16.8 k
1 0 0 0 19.2 k
1 0 0 1 21.6 k
1 0 1 0 24.0 k
1 0 1 1 26.4 k
1 1 0 0 28.8 k
1 1 0 1 31.2 k
1 1 1 0 33.6 k
reception.
Use a lower setting if high speeds pose problems
during reception.
Cross reference
