View Full Version : Minolta EP6000 error code C0070
mysticus
08-16-2007, 11:26 PM
Have checked to make sure the toner bottle is in correctly. Can this be reset? Any solutions...am listening. Thanks
mikeena
08-17-2007, 02:04 AM
i am not to sure about the reset opening it up and closing it should work. i have personally not worked on to many 6000. but what i would check is sorry if i am not politically correct on parts. so check where the toner motor is there is a white plastic piece in the toner section that the motor goes into make sure that there is nothin wrong with it. it could stop the toner from turning and that could cause the code
Mark B
08-17-2007, 01:10 PM
Reset by opening and closing front door. Motor could be bad or home position sensor could be dirty.
Luther
08-17-2007, 02:03 PM
Also make sure it is not a generic toner, have had problems in the past with generic toner bottles, also if you have had the back cover off the machine make sure the sensor on the bottom left hand side is actuated.good luck
mysticus
08-17-2007, 06:56 PM
will post the outcome as soon as I get back to the unit
