View Full Version : Xerox Docucolor 12 error 10-356
abrjown648
02-09-2005, 07:25 AM
Does anyone have any idea what type of fuser error results in code 10-356? The lower fuser roller cams up and down prior to coding, but I have eliminated the sensor. Any help will be greatly appreciated.
ManassasRalph
10-30-2007, 07:27 AM
Hope this helps.
abdou
11-05-2007, 09:20 PM
10-356 code i pws mode
remplace the fuser
NVM 744-003 was at 0
TechMate
07-16-2008, 01:54 PM
:)ec10-356 external heat roll retract motor failure-replace as necessary:cool:
Peter Montgomery
05-04-2010, 08:53 AM
Xerox Docucolor 12 error code 10-356 is caused from the External heat roll retract motor failing.
Replace this and you should be all right.
