View Full Version : Enter Account Code----- Sf-2540
hi,
i Have Sharp Sf-2540 Which Shows Enter Account Code-----
i Dint Know The Code ,how To Reset Or Enter The Copy Mode,
i Am New To This Copier, Some Body Enter The Code
please Need Help?
thanks.
blackcat4866
08-24-2007, 12:52 PM
I don't know how much help I'll be, but lets give this a try.
I'm assuming this model is an analog @ 40 cpm comparable to the SF2040 US model.
Based on that, press orange Clear, Interrupt, 0, Interrupt, 26 on the numbers, Start, than look for a menu choice "AUDIT MODE", press that number then Start. The choices are usually '0' = off, '1' = on. Then Start, CA to exit simulation. I hope this helps.
thank You Friend I Will Try This And Let You Know,
thanks For Your Help.god Bless You
ZOOTECH
08-28-2007, 12:45 AM
KHAN, if this is using the internal account control; enter the key op programs (clear-int-clear). Input your key op code and go to P10 to enable/disable account control.
