View Full Version : Enter Kye Operator Prog Sf-2540/2040
KHAN
08-28-2007, 08:30 AM
HI,
1.HOW CAN I ENTER THE KEY OPERATOR PROGRAM ?
2. my SF 2540 makes 72000 copies , i put new TONER , each time i trun it ON it runs for some minutes, HOW CAN I ENABLE OR DISABLE THE TONER REPALSHING MODE,
OR THE DEVELOPER IS TOO OLD AND NEED REPLACEMENT ?
3. HOW CAN I MAKE COPIES IN THE SIMULATION MODE,
THANKS NEED HELP ?
KHAN
09-01-2007, 05:00 AM
no Body Have The Answer,
astonishing,funny
ZOOTECH
09-04-2007, 05:14 PM
1) clear-int-clear...default passcode is all zeros. TC 22-13 will give you the current passcode if if has been changed.
2) 72k is close to the PM cycle; if it has sat for any length of time, change the DV and do a full PM (drum, MC,etc). Be sure to clear your maint and DV counters and drum and DV adjustment times. Adjust DM and ID sensors to 204.
3) TC 46-01 adjusts for exposure, several other TCs will give a copy.
KHAN
09-05-2007, 04:27 AM
thank You Mr; Zootech For Your Help
thanks.
