View Full Version : irc5185i df jam 0094 on display
macuk
07-25-2011, 08:41 PM
Via the df paper will not feed at all and green light flashes. It will not reset until the machine is turned off and on again.
Have sens init but with no success.
I have a manual for the copier but not the df. any ideas?
vigour
07-26-2011, 01:33 AM
http://www.copytechnet.com/forums/canon/22160-canon-ir-55-6570-shows-jam-feeder-2.html
5075 etc, use the same feeder
teckat
07-26-2011, 04:48 AM
A 0094 Jam code is caused by any of the feeder sensor being blocked, when the print button is pressed.
First clean all of the sensors and initialize the sensors in Service Mode > FEEDER > FUNCTION > SENS-INIT.
If jam still occurs check the sensors in Service Mode > I/O.
Service Mode > COPIER > I/O > FEEDER.
Check the following sensors to see which one is in a High state. Replace the sensor that indicates paper is present.
SENSOR
PORT
BIT
READING
PI1
0001
1
1: paper present
PI1
0004
5
1: paper present
PI5
0005
2
0: paper present
PI11
0006
5
1: paper present
PI12
0001
3
1: paper present
PI12
0006
3
1: paper present
PCB2
0004
5
1: paper present
0007
11111111: no paper
PCB3
0001
0
0: paper present
0008
11111111: no paper
PCB4
0001
2
0: paper present
0009
11111111: no paper
Part number for PCB 2,3, and 4 is FM2-1022-000
Part number for PI 1,5,11,and 12 is WG8-5593-000
PI 7,8,9, and 10 are for size detection only
Below is a diagram of where the sensors are located
01101111012
reminder----Post Separation Sensor PCB2 /part number FM2-1022-000
the Sensor Holder does not come with the new PCB2 Sensor Unit and you would need to remove it from the old unit and snap it on the new unit. If misplaced, the sensor holder is available as a service part. The part number is: FC5-3131-000
11013
macuk
07-26-2011, 11:55 PM
Thanks for all the info guys. I found that the cable from the scanner to the machine was not quite made properly. I remade the connections and Hey Presto! doc feeder now works!
