View Full Version : C280 not using fax prefix
lanierboy
07-26-2011, 10:14 AM
Hi All
Machine= C280 + FK-502
I have a customer that has installed a C280 with fax option.
When the customer uses the fax the normal number must be prefixed with a “99” to get the outside line.
Although in pbx connection setting this has been entered the machine just dials the normal number without the prefix.
Anyone had this before??
pepper38_cnd
07-27-2011, 12:07 PM
As silly as this sounds I believe that all the KonicaMinolta Fax cards only put the prefix in front of programmed speed dials. Manually dialed numbers they expect you to add it yourself.
lanierboy
07-27-2011, 12:17 PM
Hi
the machine is not setting the prefix for any numbers, it just ignores the setting, I have never had to put a 99 before a number before only 0 or 9 but the guide says 99 should be ok
pepper38_cnd
07-27-2011, 01:13 PM
There is caution in the FK-502 Service Manual that tells you you must unset the fax option after turning on Prefix and the reset it. Have you done that?
11032
lanierboy
08-02-2011, 10:26 AM
Hi All,
found the answer in the end, if you have a prefix for the fax option, when entering the number you need to place an "e" before the number then the machine knows to use the prefix. ie e01234567898.
thanks
