View Full Version : Konica IP511A system code
mascan42
07-27-2011, 02:25 AM
I have a customer that keeps getting SC4901 and 4904 codes on their 7255, and the problem seems to be corrupted system code on the controller. Problem is, I can't locate a service manual for an IP511A, so I don't know the procedure for reimaging the controller HDD. Any ideas?
Woxner
07-27-2011, 02:29 AM
Been awhile on this but if I remember it's through a parallel port. I will send you the manual email me woxner@copytronics.net
ddude
07-27-2011, 05:42 AM
Trying to install firmware via KMBS method is tough on this box-
pepper38_cnd
07-27-2011, 11:35 AM
Connect via the serial port using TeraTerminal while you see the Memory check type "KA" (without quotations) this will boot it to a DOS Prompt change Derectories and type "Restore" this will load the previous backed up version of the system code. Usually works as long as the HDD is not bad.
