Konica Minolta C252 (Olivetti d-Color MF25) - Replace Toner (K) issue
  • dufeuit
    • Jul 2025
    [Misc] Konica Minolta C252 (Olivetti d-Color MF25) - Replace Toner (K) issue
    Hi all,
    Hopefully someone can point me in the right direction as i am relatively new to these machine's. We have a C252 equivelant which keeps requesting K toner even after it has recently been replaced. We are using 3rd party Katun Performance toner which has been fine in the past but recently the K IU has been chipped, could this be the root of our issues?
    Thanks in advance!
  • D Colour
    • Oct 2008
    • 213
    Re: Konica Minolta C252 (Olivetti d-Color MF25) - Replace Toner (K) issue
    Did you use a brand new chip or is it one that has been reprogrammed? We had problems with reprogrammed chips giving us low and high toner density error codes. A right pain in the a$$.
    We now use the Katun chips.
    Everything that has a beginning, has an end.....
    • dufeuit
      Hi,Thanks for the reply. Yep we are using the Katun pre-programmed chips. Do you think itbis IU related then? Could it be a dodgy chip?Cheers
      • D Colour
        • Oct 2008
        • 213
        We have never had a problem with the Katun chips. We changed to them as they are brand new, not reprogrammed.
        You could try forcing K toner into the machine.
        If you enter service mode, check "State Confirmation" and "Level History 1"
        Ideally all the T/C Ratio should be around 7. You may find K is way down.
        • dufeuit
          Ok great I shall try that! Would the fact the isn't enough toner in the IU cause the machine to report the toner needs replacing? I've had C2557 in the past (I think)Cheers!
