View Full Version : AR-407
circling stars only in the morning hours. things i've done. this one is on a novell system and when you disconnect the machine off the network it will work as a stand alone copier fine.
1-nic card fixed for a while
2-icu pcb fixed for a while
3-ic22 and reprogramed fixed for a while
4-reformatted hd fixed for a while
called in for the 5th time in 3 weeks.
what the ---k with this machine. help much appreciated with this one. thanks t
blackcat4866
09-20-2007, 02:15 AM
The circling stars usually means a bad hard drive, but disconnecting from the network would certainly do nothing to improve your hard drive. Are you sure that it functions fine as a stand alone copier with the network line disconnected? Does it print OK when it does power up?
You may have two distinct problems:
1) Bad hard drive for circling stars/won't boot up.
2) Bad AR-PB2A Print card (and good luck finding one).
pjdbm
09-20-2007, 03:53 AM
I have a brand new nic card for this,also have the pb2a print board used
blackcat4866
09-20-2007, 10:48 PM
I'm still leaning towards the hard drive. I have had a few of these go intermittent, and a reformat will get you a few days (but only a few days).
