View Full Version : cardreader
patrick045
09-12-2011, 03:03 PM
cardreader solutions about Konica pro 920
The machine doesnot work because he need an card(reader)
I tried to solve it with HDD format but still it doesnot disapear
Please send me an solution if possible
Mr Spock
09-13-2011, 01:56 AM
Need to go into billing mode and disable the coin vender option.
patrick045
09-13-2011, 04:53 PM
thx please inform how , we are wholesaler company and not very specialized in konica
thx in advance
patrick
tech51
09-13-2011, 08:15 PM
Might need the key counter link putting back in??
patrick045
09-14-2011, 08:25 AM
@ tech 51
machine came in without card reader , any other solutions ?
rgds
patrick
tech51
09-14-2011, 06:42 PM
What message are you getting on the panel?
patrick045
09-15-2011, 10:09 AM
panel is now showing " please insert key counter "
tech51
09-15-2011, 08:04 PM
Then as I posted earlier, the Key Counter link needs to be put back in!!
ddude
09-16-2011, 05:54 AM
I think that this is a 'loop connector' that tells the machine that there is no key counter connected- if you are a wholesaler, you should have plenty of Konica machines available to check this- look for the small rectangular cutout in the machines where a key counter would fit, and see the four pin loop connector attached to the wiring-temporarily place this in your problem machine and see if it solves your problem. Even though the connector is a four-pin connector, the machines usually have a two-pin loop to complete the circuit and satisfy the machine.
