View Full Version : Transfer Belt Unir on a C450
jokacross
09-14-2011, 05:24 PM
Just want to know where I change the fuse of this unit thanks!
acusso1234
09-14-2011, 06:31 PM
If you take the unit out for 20/30 cm can notice on the front side two tiny contacts into a little black cover secured with a little black screw. it contain the fuse.
JustManuals
09-14-2011, 06:34 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
jokacross
09-20-2011, 01:53 PM
thanks acusso. one more thing this fuse is the same as the fusion unit? thanks!
jokacross
09-20-2011, 04:47 PM
Some one help? thanks
CraigW
09-20-2011, 05:09 PM
We have good luck doing the fuser and the belts with 1/16th Amp, 63ma Pico fuses.
acusso1234
09-20-2011, 08:47 PM
Same value but different aspect:
_TBU needs glass fuse.
_Fuser needs a pico (green) fuse, but you can made something connecting a glass fuse using some wire and tape or similar.
You can find the original green painted fuse into a plastic tube between the wires under a black cover of the unit
jokacross
09-21-2011, 01:19 PM
thanks!!
