View Full Version : C250 ERROR c0301 suction fan motor
yannii33
09-14-2011, 10:14 PM
Is this suction fan the m12 fan in this machine where is it located. keep getting this error code does anyone have a solution for it.
Thank You
acusso1234
09-14-2011, 10:44 PM
11781
It is located under the filter on the upper rear of the box...clean it!!!
yannii33
09-14-2011, 11:16 PM
[QUOTE=acusso1234;245644][ATTACH]11781[/ATTACHi
I have cleaned it and it spins should I replace it?
Hansoon
09-15-2011, 04:48 AM
Could this solution be of help?
http://www.copytechnet.com/forums/konica-minolta/54767-workaround-failing-fans-here-fan-m17-minolta-di-450-a.html
Hans
acusso1234
09-17-2011, 09:15 AM
You could reverse M12 with M13, why are the same, and see if the error code changes or not. This way you can tell if you have to replace the fan or the card. But if there was an ICP burned on the card, the code would be fixed and not intermittent as in your case.
yannii33
09-20-2011, 04:41 AM
Is it PWB M that need to be replaced for this code because i tried a new M!2 fan and code still comes back
Thank You
habik
09-21-2011, 02:02 AM
Thank You
ahh bugga: I have C351 and the same Issue:
I ordered new fan...and in the meantime tried one from another machine, which wasn't installed "also" properly wires tend to get squished between the mainframe of the door and the metal support plate which is also acting like a earth..
I also tend to find the foam touching the fan-- every now and then and I think this could cause that intermittent issue.
If I cut it out that the suction will be not as good and could cause build up of paper dust.
FW or anything simmilar did not work for me...unless there is a specific solution to this. Probably Board..(ouch)
11781
This is wrong. The right one is Suction fan motor M10 (9313 1000 72) 11925
acusso1234
09-23-2011, 05:50 PM
Yes you are right but, reading the first post...he asked for M12 that is located in the position that we know.
Toxic
01-16-2017, 09:37 AM
Hi,
I have the same problem, error c-0301.
Machine is C252.
Machine was working ok before holidays and after few days in cold room it shows error and jam paper when paper goes from paper tray to registration section.
I visually check 3 fans on the back of machine, they are working,somebody mention pwb-m,is it a problem?
Toxic
01-16-2017, 03:52 PM
I have to reply to myself :)
It was fan in right door M10.
It was stucked.
Woxner
01-16-2017, 05:27 PM
although these are turning there is a circuit to measure speed. i have never replaced a board for this. always been the fan
Toxic
01-16-2017, 07:06 PM
I never had this error till now on this one machine.
This fan did not turning at all and after some hand rotating it starts.
Maybe i will have to replace at end because it have some "buzzing" sound when working.
