jonezy999
09-21-2011, 03:21 AM
One 3510c I look after has the following condition and I would like to hear some of your thoughts as I'm a little baffled by this. Ok, here goes.
The original call was customer can not adjust paper cassette guides and missing bottom part of pint. Sure enough the side fence in the cassette had been broken. Stole another cassette from a parts machine and swapped them over. Figured this was going to solve the cutting off print part too,, but it didn't.
Now the problem is A4 from either cassette (this machine only has 2 cassette, 1x A4 1x A3) will shift the entire image across the page around 5mm-10mm. (long edge feed, shifts image away from short edge and drops off bottom of page). This only happens when using A4. Using A3 from either cassette will leave the image how it should be. A4 from the bypass is perfect also.
Where would you start to troubleshoot his one?
