View Full Version : Ineo 363
inutelkamo
09-28-2011, 10:24 AM
Good day..
I only found out that ineo 363 are different from 362 and 350. The drum unit, developer,developing unit, transfer roller unit and fussing unit has a predicted yeild date.
Now my question is, is it possible to set continuously those area? specialy drum unit. because when it reach the yield/or life the machine LOCKS up. even though the copies are not that bad.
Can we set it to continues? In the techrep mode?
ineo+6501
09-28-2011, 04:41 PM
Good day..
The counters can just be reset in service mode
mervyn
09-28-2011, 04:56 PM
If you update firmware with special firmware you can reset dipswitches to run to life
tech51
09-28-2011, 07:37 PM
You can set the drum life to no stop like you do on the colour machines. You still get the change drum message but the machine wont stop. By the way the firmware only disables the fuser end of life warning.
mervyn
09-28-2011, 07:45 PM
If you do the firmware and set dip switch 50 bits 4 , 5 , 6 , and 7 to 1 and then Fix , it diables the drum warnings from displaying and the drum can be run to life.
mervyn
09-28-2011, 07:47 PM
We do it on all our machines and it works.
tech51
09-28-2011, 07:49 PM
I must read the info ive got again, must have missed something!!!!
mervyn
09-28-2011, 07:52 PM
Tech Bulletin Number 7528 dated 6/9/11 is the one you want.
tech51
09-28-2011, 07:58 PM
Tech Bulletin Number 7528 dated 6/9/11 is the one you want. Thanks, to be honest I dont get too involved with these particular boxes but was obviously given some duff information, will sort it out and pass it on!!!!
mervyn
09-28-2011, 07:59 PM
Good luck , its easy .
inutelkamo
09-29-2011, 01:03 AM
Thnx, but there is no option in service mode to set drum life to continues, jst like we all did in colored machines.
inutelkamo
09-29-2011, 01:05 AM
what version of firmware is that to be specific? tnx in advance
mervyn
09-29-2011, 02:31 PM
Version A1UD0Y0-F000-GC1-C2.exe found under special firmware
System 2 Unit Change- set toner near empty to NO
Enhanced security mode set to NO Stop
Softswithes 51 set bits 4 , 5 , 6 , and 7 to 1 and fix
inutelkamo
10-17-2011, 12:19 PM
hey!
Sorry for late reply but ahmmn, i have cleared the counters and set new prediction date.
I just went to service mode and counters of special parts, now if you can highlight the parts you want to clear, just press "C"
Hope it will work, i just have to revisit it on 19th day of this month, the first prediction lock date.
thx..
