Desert Rat
10-02-2011, 05:48 AM
:confused:
I feel pretty stupid now. Here's how it started.
I got this ES855 for a long time customer. While checking is out I noticed that from tray 1 14" copy was not at 100%.
It was off just a little. I made a couple of adjustments and it just got worse. Putting the settings back did not seem to help.
So I started looking through the handbook, and it got even more worse. I tried using the grid (1 and fax). I could not get
"A" measurement to 200mm and the image was getting further off the page.
When I started I have a test target with a 6" measure on it to measure to check if 100% is 100%. It was off by .1".
Not much for most accounts, but I prefer it to be in spec. So I adjusted 05-340 from 128 up and down and no luck
even when I put it back it was off more than before. Reading in the book I looked at 05-401 using the grid again and still
could not get it to measure correctly and get a copy that was completly on the page.
I ended up adjusting one program at a time and making a copy off the glass and measuring the 6" line till it was 6"
on X and Y axis. The copy was still off the page. So I adjusted the laser start position untill the page was centered
on the X and Y axis. I was doing this from tray one with 14" paper and tray 3 (LCF) with LTR paper. Adjusted the
bypass guide a little to get it into place.
When I ran through the doc feeder the image was off the page by about .5" when originally on checking everything was
sorta ok but I could see it was out of spec a little.
The prgrams I adjusted were in the 05 mode 340, 405, 401, 410.
Now I have to much edge erase at the front of the machine as the paper exits. About 6mm and none at the top as when I
originally started.
I need some help to get this back in the real world. I was on this unit for about 4hours just doing this after about 4 hours
of just taking it apart and cleaning it. My mind is really scrambled right now. I am thinking about putting those 4 programs
back at the defaults and starting over or maybe I will just see if I can correct the feeder cross track as it is.
I'm not sure which would be the best thing to try next. :confused:
I have gone through this on a couple of Canons and things worked out well, but something seems to be lost in translation
on this model.
Anyone up to this challenge?
DR
originally started.
on this model.
DR
