View Full Version : Error Code e-studio 455 CDF0 error code
gregoriojc
10-04-2011, 08:56 AM
Greetings to everyone,
I have toshiba e-studio 455 showing CDF0 error, Please let me know what does it mean and what should I do , thanks
gregoriojc
Meach
10-04-2011, 03:06 PM
CDF0 Offset tray related
service call
Initialization error of the offset tray: The home position of
the separator cannot be detected when the power is
turned ON.
[CDF0] Initialize error of the offset tray (e-STUDIO205L/255/305)
(1) Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
(2) Check if each connector between the OCT board (CN261) and LGC board (CN302) is
disconnected.
(3) Check if each connector pin is removed or the harness is broken.
(4) Check if any conductor pattern on the OCT board and LGC board is short circuited or open
circuited.
(5) Replace the OCT motor.
(6) Replace the OCT board.
(7) Replace the LGC board.
gregoriojc
10-06-2011, 11:24 AM
ok thank you very much, i will follow that one
thank you again,
gregoriojc
Mad_Coachman
10-14-2011, 05:19 AM
If someone recently worked on the post-fuser section the CDF0 was caused by not lining up the offset link with the rollers.Remove the unit directly above the fuser and line up the offset link with the corresponding one on the exit rollers.I have NEVER seen any of the electrical components cause this code! This is most likely just a mechanical mis-match of the linkage.
michaelc
10-16-2011, 02:42 PM
Sounds about right. I replaced all the sensors etc in the sorter. Still same code. Put a new one in and it worked. I will give that a try next time I get the fault.
