View Full Version : oce cm5520 km bizhub c552 smearing magenta and yellow.
dqydj
11-03-2011, 09:30 PM
Magenta and yellow are smearing lead to trail towards the center of copies & prints.
Replaced both IU's, transfer belt and transfer roller. black and cyan are fine.
Any ideas? I'll attach samples.1270012701
minimerlin
11-04-2011, 04:35 PM
Any ideas? I'll attach samples.1270012701 Not seen that actual problem before..but maybe to do with print head? Try giving the windows a clean? I take it you have checked for anything that could cause a physical effect? Is the problem visible on the belt before transfer? Remember the order in which the colors of the copy are built up!
rustymarko
08-07-2012, 09:38 AM
Did you ever get this fixed or figured out? My CM5520 is doing the exact same thing i just recently replaced the Transfer Belt ($500) on it and it was fine for like a day then it started doing it again UGH.
Thank you,
Marko
