View Full Version : C203 Colour registration out on yellow
Bmonkeyltc
11-03-2011, 10:04 PM
Hi
I have a C203 that has a yellow registration out. When i do a colour registration adjust page the yellow vertical bar is all the way over to the left almost on top of the magenta bar. Changed the yellow lazier unit, did not work, then swapped the magnate with the yellow laser, did not work, then swapped yellow, magenta and cyan around still no luck. New yellow image unit and transfer belt swell as cleaned the idc sensors and checked their state in service mode, all okay. Also getting a P-22 Code. If i print anything without yellow in it all great, but put yellow in and it goes out of wack.
Please help!!!!!
mervyn
11-04-2011, 03:06 PM
Sounds like lazer is out of alignment , otherwise you may have to do a registration setup .
