View Full Version : Motor erro Konica 7235
Don
11-08-2011, 01:35 PM
When getting F-26-3 error on Konica 7235 you can check the main motor function in diagnostics and the motor tests good. But when you try to run the copier you get 0003 & 0005 errors along with F-26-3. After replacing the the toner density sensor and developer without solving the problem we found that one of the four motor leads solder connection had come undone. The experts recommended replacing the main motor but we resoldered the lead an it works perfectly. The main motor receives it power from two different sources and that is why it functions in test mode but not when you try to run the copier
