View Full Version : Error Code Konica c451 with IC409
Cay
11-08-2011, 07:46 PM
I recently reload system code via USB on the IC409. Applied suggested patches.
Under Utility/Counter>Controller Details, I get the following message:
Maitenance
Requried D-1
Does someone know what that message means? I haven't been able to find anything on it.
Mr Spock
11-09-2011, 12:15 AM
I can not find it but will suggest clearing the cmos of fiery and making sure you made the thumb drive correctly.
Cay
11-09-2011, 12:31 AM
I will try clearing the cmos.
FYI, this message did not appear right after the system reload. It took a couple of days before it showed up.
scottybbb
11-09-2011, 12:39 AM
D-1 is a warning code or P-code telling you to clean the slit glass.Check under counters in service mode.
Cay
11-10-2011, 12:39 AM
Thanks Scottybbb, that was it. I assumed it was a fiery code. If I had opened Command WS it probably would have made it more obvious to me.
Thanks again.
