View Full Version : abort code 0x00e00133 Bizhub 350
yannii33
11-20-2011, 09:23 PM
Can someone please tell me the what this code means and the fix for it 0x00e00133 for a bizhub 350
thank you
Nor
11-20-2011, 10:35 PM
check memory , remove, clean contacts both sides, and reseat. If that fails, try the trouble reset.
You could try reinstalling firmware, and failing that change MFBS board.
Socialist
11-22-2011, 04:33 PM
0x00E00133
The interface cable for the HDD is not fully seated or NVRAM has failed.
Please confirm the HDD cable is fully seated to the MFBS or the Encryption Kit. Replace the NVRAM. If the problem is not resolved, please replace the MEMS board (p/n 4551 2039 01). If necessary, replace the MFBS (p/n 4551 R900 00).
Optional HDD (HD-504) is not installed but HDD is setting in machine is incorrect.
Enter the service mode, select System Input, then select Hard Disk and change the setting to No.
Optional HDD (HD-504) installed without any extra memory.
Install the optional memory module (Item #4551641 - 32MB)
