MWMACH
11-29-2011, 10:54 AM
Hi, we purchased a used estudio 2500c a while ago and everything has been fine up until now. When we purchased the unit, the waste tray had to be replaced in the first couple of weeks, after that, plain sailing.
Message today to change the waste toner cartridge and someone tried to empty and replace the old unit (didn't know there was a new one in the cupboard). We got an error CE40 after this. We have now put in a brand new waste toner cartridge and still the error happens.
We have googled this error and tried a few things.
We have cleaned the units with the cleaning "wand" inside the main cover. We have pulled the other rods (one on each color) out and back again. Then done these procedures:
08-573 to 576 shows 573=1, 564=0, 574=0, 575=0, 576=0
05-391-0 to 3 with in spec
05-390-0 to 3 seems to have isolated the problem down to the ""high density pattern abnormality" on the yellow. The other colours and black all come up with-in spec.
We set the variables 08-556 and 08-557 to 0
Then "enforced performing of image quality open-loop control (08-394)
Test output with 04-270. No yellow printing on the test pages was the results.
The procedure advises to replace the image sensor.
When running the developer function test 05-200 we get the error C3B0. Before the screen goes to the the "call service" message the scan results show each colour having three results. The yellow being the one that is different as listed below. All the others show the top and bottom voltages (i assume that's what they are) at about 1.46v
Y .16v
Y *****
Y 1.46v
We have no specific information but there seems to be an indication from what I have read that the Developer tanks should be cleaned and the image sensors cleaned (or replaced). I assume the developer tank is the unit below the toner cartridges.
Since the whole thing started with changing the waste toner tray, I feel that a defective part is unlikely and that we have managed to get gunk over a sensor or misaligned something or pressed the wrong button.
Does anybody have a procedure on how to identify and remove the developer tanks for cleaning? The image sensors, where do I find them?
Am I completely on the wrong track?
Thanking you in advance
Regards Neil
Y .16v
Y *****
Y 1.46v
Regards Neil
