View Full Version : Toshiba studio 650 wait after copy for 15 seconds
ELIAS G
12-15-2011, 02:34 PM
e studio 650 says wait after the end of copy for about 15 seconds (the machine is runing) and then goes to ready.
I have change all the thermistors , toner motor and recycle motor are ok.
Any ideas.
michaelc
12-15-2011, 08:43 PM
are you doing more than 1 copy while it does this?
bojans
12-15-2011, 08:44 PM
Try formatting HDD.
ELIAS G
12-16-2011, 07:43 AM
GOOD MORRNING FROM ATHENS
THANK YOU ALL
MICHAELC : it does intependently of number of copy one or more,exactly at the end of procedure .
BOJANS :format is ok but the problem stays.
fourl6
12-16-2011, 11:03 AM
iv had wait issues caused but temperature/humidity sensors. no idea where they are on a 650 sorry.
i'd also give the IH board a good clean.
Cheers Cam
esam ramadan
12-16-2011, 07:08 PM
set 08-803 to 2 if it not 2 it can make this problem
michaelc
12-17-2011, 08:20 AM
I know on some other models thermistors can cause issues like this. Maybe worth giving them a clean (or replace if worn) and also the IH board like fourl6 suggested. Have you also checked your toner cartridge, toner unit and waste toner recycle unit. Also had a semi worn dev drive gear (the one on the back of the dev unit) give a similar issue before it failed. It used to go around the shaft 360 then sit back in position and drive for a bit.
JustManuals
12-18-2011, 12:05 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
ELIAS G
12-19-2011, 09:12 AM
Good morning from athens to all
have a good week and a happy new year.
Many-many thanks to all for your help.
specially to esam ramadan . your help was the solution in this problem.thanks a lot
:d
esam ramadan
12-25-2011, 08:15 PM
:d
YOU ARE WELCOME
