View Full Version : toshiba e-163 unable to install a driver in computer
sjinachandran
12-26-2011, 10:45 AM
Dear firends,
I try to install the toshiba e-163 driver, but i unable to install, while instalation the message shows some of the files are missing, but i tryed with orginal CD, i also try with another system with another driver CD but the trail is vain, i faced the same problum. how can i solve the problum.
S.JINACHANDRAN
Outlander
12-27-2011, 09:20 AM
Not enough info for right solution :(
Usually if you have original CD Toshiba Viewer, it runs installation via Autorun. After few steps you must put USB cable into e-STUDIO and Tur on the machine. Installation will be completed.
Which way you use for installlation- CD autorun, add printer, doubleclick exe?!?!?
What OS do you have?
sjinachandran
01-12-2012, 05:04 PM
i download the driver from toshiba network, and installed those driver. but the system shows some files are missing and shows "please insert driver cd". Then how can i installe the firmware for this 163 machine without network card.
Outlander
01-18-2012, 06:17 PM
Usually you will be able to download complete CD from web cca 315MB (Toshiba Viewer 2.0), it'sISO image. Burn disc and try to install.
For Firmware upgrade, on models 163/166/203/206/181/211 and 165/167/205/207/237/182/212/242 without Network Controller, you will need a Special Software Upgrade Tool.
didi2005
02-10-2012, 10:54 AM
Below is how i install driver:
1. Connect usb cable from MFP to PC
2. On the MFP, and your PC will detect new hardware
3. Install the USB driver
4. Once the USB driver is finish install, it will auto go to driver installation, just follow the on screen instruction
