View Full Version : bh 211 light copy
abbas saeed
01-11-2012, 07:29 PM
How are you
I have a bh 211 , I replace (dr114) and (dv110) but after that , copy light
Before changing the (dr114)and (dv110) the copy was good except for some lines
help me
thank you
Darren King
01-11-2012, 08:45 PM
Did you run an F8 after replacing dev? Also reset supplies life counter.
Hope this helps.
Darren
mrwho
01-12-2012, 08:27 AM
Also check the following:
- If you did take out the corona unit, make sure it is correctly placed. It is possible to close the IU with the corona in the wrong position;
- Make sure the drum is properly grounded. I once stuck a screwdriver at the backside of the drum flange in order to keep it in position while rotating it by hand, and misplaced the ground conductor inside the drum by doing it.
abbas saeed
01-12-2012, 02:53 PM
Thank you my brothers and I will try to find a solution that gave me
abbas saeed
01-23-2012, 03:21 PM
I have found the solution
There was a problem
Installation
Thank you
