View Full Version : DiAlta Di200 - network card problems
smart-refill
01-15-2012, 09:59 PM
Hello
I have a Di200 with Pi3502.
Today I tried to print with my Di200 for the first time.
The protocol address of Di200 is 10.233.21.108. Today I realized a short network with my PC and Di200. (the PC has 10.233.21.101 protocol address)
When I tried to ping from my PC ping 10.233.21.108 errors returned. sometimes the ping was ok, but most of the times the ping retuned errors.
I did not menage to print a test page.
Can anybody help me?
Thank you!
RRodgers
01-16-2012, 03:30 AM
Hello
Thank you!
I believe those little PI's are little external fiery print controllers. Those are kinda known for the HDD's to go out on them after a couple/few years. Can you get to the network settings from the copier? Maybe try a ping 10.233.21.108 -t and let it run to see if it pings over a given time of about 3~5 mins. If it pings then stops then pings then stops it's the fiery stuck constantly rebooting and probably time for a new hard drive and OS reload.
Hansoon
01-16-2012, 10:05 AM
Bad news. Those NIC's go bad by aging. No replacement from the factory since years. About a million posts here in this forum about that issue.
Hans
smart-refill
01-16-2012, 08:30 PM
Thank you Hans!
I will try to print using the parallel port.
Best Regards!
Sorin from Romania
