View Full Version : Miscellaneous Biz Hub 161F
SHOP NASI
02-29-2012, 01:15 PM
Display has a Black bar across or it reads "Please Wait", does nothing else.
JustManuals
03-01-2012, 12:22 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Hansoon
03-01-2012, 06:02 AM
Reseat ribbon cable going from scanner to logic board. Remove NIC for testing if machine has one.
Hans
SmellsHot
03-01-2012, 05:04 PM
This is why so many dealers switched to Muratecs....the 1610f or 161f are garbage. More than likely the NIC is pulling too much juice and is causing this issue. Remove the NIC (as mentioned above) and see if machine will boot up. If you're really lucky and they don't print at all, just put the board in your pocket :)
They came out with updated boards for this machine. See if yours is updated or not...i believe theres either a yellow or greeen dot on the board itself.
SHOP NASI
03-01-2012, 06:05 PM
Thank You to both of you, it is the Nic I/F Board
