samoilenco
03-02-2012, 07:09 PM
Hi all. As I need some advice from a specialist Minolta copiers. Specifically I recently purchased from a used Bizhub C450 and I fail to realize that the network card does not work print.
In my administration menu missing IP configuration settings and service menu also configure the network card.
New symptom that apear now when made rewriting the firmware is that suddenly appears from time to time error code C-D36E. From what information I found on the Internet would be the problem is the NVRAM. Is there any way to fix this? Because I still can not use print controller. Can anyone help me with advice to remedy?
If you have a solution or advice please help me to send me an answer to: office@studio-pc.net
Tank you. Sebastian
Tank you. Sebastian
