View Full Version : display bizhub C352
eugenionitza
03-05-2012, 01:55 PM
Hi
I have a KM bizhub C352and I just changed the touch screen but now
I have a new problem with the display , it is not lit 100%
the display is very dark, lighting level is almost 5%, but the brightness or contast buttons are not at fault
Does anyone know what the problem is?
Eugen
eugenionitza@yahoo.com
blaze2000
03-05-2012, 02:29 PM
reseat the connectors on the display. Might want to check the corresponding connections on the circuit board as well.
eugenionitza
03-05-2012, 02:38 PM
I changed control panel with another control panel and the problem is as identical
the cable is ok no damaged ...
thanks
Eugen
blaze2000
03-05-2012, 02:58 PM
Then you will want to check your input voltages to make sure you are getting the right voltages coming into the display.
JustManuals
03-05-2012, 11:52 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
MCBIG
03-06-2012, 04:38 AM
Check PJ5IPB pin 4 on the IPB for 24V. Also check PJ12IPB pin 24 for 24V. If the 24V is missing, replace the IPB PWB.
