View Full Version : KMC652 Error code C-6104 code.
laserman06
03-22-2012, 11:08 PM
Have a brand new KM652 with a C-6104 code. Any suggestions? I am asking for a friend of mine.
bizhub1
03-23-2012, 03:18 AM
Check the cleaning roller for the dual scan CIS in the RDF. Possibly a connector,sensor,belt, etc
C6104 Opposed board home
sensor abnormality (initial)
• The back side cleaning sensor (PS9) does
not change from H to L even after the lapse
of a given period of time after the home
position detecting operation is started at the
initial operation.
not change from L to H even after the lapse
initial operation
JustManuals
03-23-2012, 07:18 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
EarthKmTech
03-24-2012, 12:08 PM
the second side cleaning brush is rotationally locked when the jam release door it sits in is opened. ensure that door is closed properly.
cap0319
11-01-2016, 05:36 PM
I just got this on a c552ds after updating FW to the latest - prior to the FW update this unit worked fine.
Any thoughts would be very welcome.
I checked the second side cleaning brush and jam release door - reset all ADF connectors and found no issues with the covers off the ADF...
emujo
11-01-2016, 06:05 PM
You realize this thread is 5 years old...did you by any chance install the non-DS firmware? Emujo
cap0319
11-01-2016, 07:10 PM
Yessir I realize it (I try to search the forum for answers before posting).
I used the only C452/552/652 FW that is on MyKM... At least that I can see.
Synthohol
11-01-2016, 11:46 PM
cap0319, its a dead discontinued boat anchor. go back to the ver of FW that was on it when it worked and walk away slowly.
cap0319
11-02-2016, 01:15 AM
I would LOVE to do that, wouldn't I need a copy of the old FW to do so? Sorry if that's a dumb question I have zero experience rolling back FW.
Also, the reason I was trying to update FW anyway was because it would randomly drop off the network AND PageScope was completely unavailable at all times (Yes, I tried all three web browsers AND top.xml...)
Synthohol
11-02-2016, 01:29 AM
wait, 6104, if i remember, take the cleaning plate on the slit glass and slide it both ways fast a couple dozen times. it may start moving properly. and clear the code in system 1 initialization system error clear.
emujo
11-02-2016, 01:31 PM
Your post was an error on the C552DS, you state above that you "used only the C452...FW on Mykm". If this is true then you have indeed loaded non DS firmware on a DS machine. If you have access to MKM go back and download the C552DS firmware and reload. Emujo
cap0319
11-02-2016, 02:06 PM
On MyKM the only FW available is in a folder named "C452/C552/C652".
I can post a screenshot if you'd like.
emujo
11-02-2016, 02:51 PM
34632
Either you're not direct or dealer KM, or you have no idea of where to look for firmware on MyKM..C652/552DS firmware is readily available. Emujo
cap0319
11-02-2016, 06:42 PM
34634
emujo
11-02-2016, 07:27 PM
Well that's just wonderful...Can't really read it, but I'm pretty sure it doesn't look much like the "actual" My KM website. Can't really help you out here..Emujo
mx6turbo89
11-03-2016, 12:08 AM
Here's the correct firmware: https://www.dropbox.com/s/doyofa64o746zza/C552DS_C652DS_A1DM0Y0-F000-G00-D1.exe?dl=0
cap0319
11-03-2016, 02:54 PM
Here's the correct firmware: https://www.dropbox.com/s/doyofa64o746zza/C552DS_C652DS_A1DM0Y0-F000-G00-D1.exe?dl=0Thanks bud, srsly.
