View Full Version : konica minolta di 470 print controller error code 1808
brent
04-04-2012, 10:40 PM
at least that is what I thought it said
do I need to re seat the print controller
to the machine again. or what is the
problem. any thoughts?
brent
JustManuals
04-05-2012, 02:38 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Hansoon
04-05-2012, 06:35 AM
Reseating the controller might help indeed and also:
From the "Solutions" list:
Solution ID TAUS0644762EN* Solution Usage 1
Description
Intermittent C1808 service code being indicated on the copier.
Solution
Cause:
The Power Relay Wire for the Controller is improperly mounted. Because of this the relay wire has become pinched/trapped between the print controller
assembly and the PWB-B circuit board causing the service code.
Solution:
Make sure the Power Relay Wire is routed correctly. It should be held in place by 10 wire saddles that run below the PWB-B and down the lower left corner of
the copier. See the attached PDF file which outlines in detail the rout the harness should follow.
Hans
brent
04-05-2012, 02:53 PM
will give it a try. thanks
brent
