View Full Version : Miscellaneous Scan SMB with MAC 10.7
bartrick
04-17-2012, 06:23 AM
I know there are posts on this already but, i need to talk to someone who has actually gotten it to work. I have installed the updated firmware for this issue and gone Thur all the settings required on a C360 and C552 and neither of them will work. We have a demo to a company that user's MAC's and need to find a fix ASAP! The customer wants to use smb not ftp which does work, so any help with this would be greatly appreciated.
Mr Spock
04-18-2012, 01:23 AM
I have not had to do this yet buy this is the latest bulletin updated last week.
CAUSE: Apple® has changed from SAMBA to their own SMBX. SMBX supported SMB 1.0, SMB 2.0 and assume Unicode.
SMB Scan from Konica Minolta MFPs no longer functions at this time.
SOLUTION: Konica Minolta has released Special firmware to correct this issue for the following models.
bizhub C652DS/C552DS version GC6-C5
bizhub C360/C220/C280 version GC6-C6
bizhub C652/C552/C452 version GC6-C5
bizhub C650/C550/C451 version GPG-R6
bizhub C353 version GPG-R6
bizhub C253 verson GQG-R6
bizhub C203 version GRG-R6
bizhub 652/552 version GC3-F7
bizhub 423/363/283/223 version GC6-C8
bizhub 501/421/361 version GDL-21
bizhub 601/751 version GCH-20
Notes:
1. The firmware is available via the Konica Minolta Download Selector.
2. The following firmware versions listed below were originally released to correct this issue but have been pulled from the Download Selector due to a bug, please use the firmware versions listed above.
[DO NOT USE]
bizhub C353 version GPA-R6
bizhub C253 version GQA-R6
bizhub C203 version GRA-R6
bizhub C650/C550/C451 version GPA-R6
3. Konica Minolta is working on releasing Special firmware for the following model(s).
bizhub C35
bizhub C25
4. As a Scan to SMB workaround, please use Scan to FTP.
The GUI for the FTP Server was removed, so to use Scan to FTP you have to activate FTP Server via the Terminal first. For more information please see Apple® Article HT4704 - Lion Server: Enabling the FTP service (http://support.apple.com/kb/HT4704).
5. Please be aware that the FTP service with Macintosh® OS 10.7 "Lion" is not secure.
6. There are no plans for the development of special firmware to support 10.7 SMB scanning for the following models;
bizhub 500/420/360
bizhub 600/750
bizhub C250/C252/C300/C351/C352/C450
morpk
04-18-2012, 09:50 AM
I have done this a few times what machine are you using for Demo ?
The folowing is for a C360 after you do the firmware update login as admin and go to network settings- SMB- client change NTLM authentication to V 1/2 also make sure that the time on the MFP is the same on the Mac
15302
Hope this helps
bartrick
04-19-2012, 04:45 AM
Thanks everybody for all the good info!
Spidula
04-19-2012, 07:52 PM
Did you get it sorted??
