View Full Version : c220 double impression
bkamoga
04-19-2012, 07:04 AM
i have a printer C220 it gives double impression prints
l have done stanblization, i have reset the screw
but all have refused some help thanks
HoonBoy
04-19-2012, 10:15 AM
Possible cause is "bad" paper. Had this problem once...I swapped paper
for different brand and problems were over.
From bulletin:
With C360 series, when printing by using some paper kind in low coverage, fusing roller become dirty.
[Cause]
Paper dust and toner accumulate gradually on the surface of fusing roller each paper feed.As a result, fusing offset occurs.
[Action in the field 1]
In order to clean fusing roller by user, added the function of fuser cleaning mode.
Firmware: Ver. GC5-C6 and onward
Fuser cleaning mode is appeared in Administrator Settings by setting Software Switch to the following setting
with firmware of Ver. GC5-C6 and onward.
Software Switch No. :HEX Assignment 00 :HEX Assignment 40 :
15
This modification is not applied. (default)This modification is effective.
[Administrator Settings] -> [System Settings] -> [Expert Adujstment] -> [Fuser cleaning]
[Action in the field 2]
Even Ver. GC5-C6 backward is installed, the same remedy can be performed in service mode.
Image:
Peper Size:Peper Type:The number of
sheets/Interval:
Solid red image (Density 200 and over)
[Service Mode] -> [Test Mode] -> [Halftone Pattern] -> [Red]
A3
Thick 1 mode (Plain Paper can be used. Setting thick 1 so as to slow down printing speed)- If it's after occuerring image problem, printing 2 sheets and over.
- If preventing image problem from occurring, printing a sheet with each printing 5K.
blackcat4866
04-20-2012, 12:04 AM
Double impression at what interval? If it's the fuser it should be ~175mm.
AjitN
04-20-2012, 03:52 AM
I face this problem for Magenta color, which got resolved by replacing Magenta Drum Unit,
Hope this helps
Ajit
bkamoga
04-25-2012, 11:35 AM
Double impression at what interval? If it's the fuser it should be 175mm
l dont understand this value pliz some guardlines thanks
blaze2000
04-25-2012, 12:06 PM
What he means is that you should measure the distance from the original/ actual image to the point on the sheet where you see the ghost image. That distance, if 175 mm is being caused by the fuser, less than that is probably caused by the drum.
jay.ashara
02-12-2013, 02:03 PM
From bulletin:
[Cause]
15
Image:
sheets/Interval:
A3
Can u please provide me with the Firmware u have mentioned here. I have fmw ver. C3.
And the image shadow occurs at around 95mm So as per the comments its not the fuser problem..
and I didnt get what is this 5K in the last line.
PeterG
02-13-2013, 04:16 AM
The fuser becomes contaminated from using "recycled" paper.
Try good quality paper & your problem will probably disappear.
i have a printer c220 it gives double impression prints
did you cleaned idc sensors underneath the transfer belt?
JustManuals
02-14-2013, 12:41 AM
Paul@justmanuals.com
wseyller
02-14-2013, 02:19 AM
Please delete my post.
Sent from my Galaxy Nexus using Tapatalk 2
