View Full Version : CQ Bizhub 6501 goasting image
susang
04-23-2012, 05:28 PM
I am having a problem with ghosting in all four colors. Have three new dev units and drums black has not been changed and new caronias any ideas?
eifling
04-23-2012, 08:12 PM
Where exactly is it ghosting? lead edge, tail? The entire sheet? What kind and gsm or stock? Maybe you could post a pic.
susang
04-24-2012, 02:01 PM
I have tried both #80lb cover which is what the job runs on and also #24lb Navagator. I am attaching a couple of pics to show you.
HoonBoy
04-24-2012, 08:38 PM
Would search it in transferbelt...
JustManuals
04-24-2012, 09:12 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
smokeetr
04-25-2012, 12:05 AM
Check drums and make sure you took the screws out of the cleaning blade
susang
04-25-2012, 01:20 AM
Service was in today and changed everything to do with transfer no luck. They have escalated it to a service person further up the chain
susang
04-25-2012, 01:22 AM
They are coming back in on thursday will have service check
kalindd
04-25-2012, 09:15 PM
This looks like cyan dev. unit is failing.
This has nothing to do with transfer belt.
You can try with adjusting Covered Margin Fine Adj. (Process Fine Adjustment) set it -5 and see if there is any luck.
susang
04-26-2012, 03:48 AM
Problem is it is doing it on all four colors
