View Full Version : Error code C2557
LennoxD
04-26-2012, 05:09 AM
Where is the TCR Sensor located? How can I get to it to clean it?
Mr Spock
04-26-2012, 05:28 AM
depending on model either dev unit or drum unit or around drum unit looking at drum
Max Kilby
04-26-2012, 06:07 AM
What model are you looking at?
EarthKmTech
04-26-2012, 06:32 AM
How about providing the model so someone can actually answer the question and give advice about the possible causes.
If your a technician, id be considering a different career path.
LennoxD
04-26-2012, 12:29 PM
Yha I derserve those comments. The model is Bizhub250
fixthecopier
04-26-2012, 12:43 PM
Cleaning the sensor will do no good. You need new developer, and if the right side of the drum is scratched, new dv collars and a new drum.
LennoxD
04-26-2012, 01:19 PM
I replaced developer and drum unit. Error cleared and a few hrs later customer called back saying error was again displayed
habik
04-26-2012, 01:48 PM
Have you got enough toner in the dev. unit ..is it not starving the dev? check that first. You may have a problem with the toner hopper. take the hopper out completely and clean all sensor at the back for toner empty and toner cartridge present. Next clean the IU cartridge sensor and lastly the Front and rear Calibration sensor. when you pull the transfer belt out you see them. Dust it off and wipe it with alcohol. Put all together and do Full toner add for all colors and image calibration Gradation adjust .
Let us know how it went.
Albonline
04-26-2012, 02:01 PM
I think this is a bh250 and he has the worn developer collor symtoms showing up. was the developer unit changed? or just the powder?
Darren King
04-30-2012, 12:05 AM
If you have a ring around the rear of the drum, be sure to replace the transfer roller. That is what causes it, not the worn spacer rollers.
Hope this helps.
Darren
kmhri5
04-30-2012, 01:05 PM
If the machine is old you could have problem with sub hopper, check solenoid on it. The sponge on it can cause it to stick and sub hopper continues to deliver toner to developing unit.
Hansoon
04-30-2012, 01:43 PM
If you enter:
c2557 - Search Results - Copytechnet.com (http://www.copytechnet.com/forums/tags/c2557.html)
in your browser you'll find around 40 million or so entries about this issue...................
Make yourself a coffee and some sandwiches and have a good read :)
Hans
