View Full Version : Error Code Oce error code 0810
tmaze01
05-18-2012, 05:55 PM
Hi,
I am having a poblem with an oce 7050 wide format plotter/printer with a code 0810
(one of the NTC ) reading high, i did notice some toner spill in the paper path can someone
please tell me if that can cause such a code and how to reset this code???
Thanks in advance for your help:confused: ..... :mad:
JustManuals
05-18-2012, 07:14 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
montana
05-18-2012, 09:55 PM
flashing exp.
LED +2
0801 110000001 The correct fuser
temperature is not
reached within a specific
time
Check front fuser 08E1 and
rear fuser 08E2
Check main controller
22PBA01 (See 22 Con.
page 401)
Check NTC’s
0802 110000010 Within 10 sec the
fuser must have
reached a temperature
of 100 °C
Check NTC’s
Check heaters 08E1 08E2
page 401)
Wires SSR 08S3 interchanged
(See 08 Fus.
page 402).
0803 110000011 Fuser temperature
higher than 330 °C
Paper in the fuser
SSR 08S3 switched on
continuously
page 401)
0809
0810
0811
0812
0813
0814
110001001
110001010
110001011
110001100
110001101
110001110
an NTC indicates a
temperature which is
too high
NTC left
NTC middle left
NTC control
NTC middle right
NTC right
NTC absorber
Check wiring
Check corresponding NTC
To check: disconnect the
indicated NTC and connect
it to a multimeter to measure
the resistance. Run
SDS test -1, 0. There must
be a uniform decrease
(from 1.5 Mohm to
700 kohm) of the resistance.
If this is the case, the
fuser can be causing the
problem
22PBA01
Short-circuit
i hope this help....good luck:)
