View Full Version : TaskAlfa500CI
kyocera.team
06-05-2012, 03:43 AM
I am facing problem with taskAlfa 500ci
the problem is machine keep running over and over until the copy getting very light once i pull out the developers units and shake it
then insert it back the first copy is very good and very clear but machine still running over and over ?
i changed DLP's units -swap DLP's units with other machine ,but the problem still there ?
any idea ?
blackcat4866
06-06-2012, 01:11 AM
Does your machine have the new style developing motor? There's a bulletin about wholesale changes in motors on this series. =^..^=
kyocera.team
06-08-2012, 07:14 PM
developing unit has been changed by new one but still the same result ? can you please attach the bulletin ..
thanks
blackcat4866
06-09-2012, 01:36 AM
... and the developing motor? =^..^=
kyocera.team
06-09-2012, 04:14 PM
thanks for your reply
i did also ....
i am thinking also about the front main and sub PWB ?
blackcat4866
06-10-2012, 02:46 PM
Those items are next in my list of possibilities. =^..^=
kyocera.team
06-12-2012, 08:16 PM
sub and main PWB has been changed but same problem ,also i change the engine PWB still the same ,H.D.D also ??? and for sure firmware V13 ... any other option ?
thanks
blackcat4866
06-13-2012, 01:50 AM
Post some samples. =^..^=
NeoMatrix
06-13-2012, 08:12 AM
Are the TA500Ci the same as the TA552ci ?
We don't have a TA500ci in the field...
RE : Developer Main motor loading.
The TA552ci displays a C2102 code on the display if any of the developer units lock up. Ie. Main motor jam.
This lockup can happen from brand new, as the dev units are transported in their boxes on their very ends and the developer inside
the unit packs down hard toward one end of the tank. If you can't rotate the mag roller in dev unit by hand you should shake
sh!t out of the dev unit and rotate it until you see an even coating of developer on the mag roller, NOT the 2nd toner roller.
Check the toner roller dis-engage bar at the back of the dev unit is over top of both of the tabs that control the toner roller dis-engage.
I assume you have done an AC U127 as per the norm ?
Try the normal user gray scale colour calibration as well. System |Maintenance| Grayscale |
Grey scale adjustment give a more indepth adjustment.
Of course this will only work if the TA500ci and TA552ci machines are similar. At best it may jog a light-bulb.
NeoMatrix
06-15-2012, 03:44 AM
"I assume you have done AC U127 as per the norm ?"
Solly olly that should have been U464 for the Kyo...
kyocera.team
06-29-2012, 12:40 PM
ufff ..i am fed up still same problem ..???
Venom
06-29-2012, 10:20 PM
Could be toner add motors. Since it measures toner at the toner cartridge it won't give an add toner message, if toner motor doesn't turn, the developer unit will starve and will start pulling developer, hense...shaking the developer unit temporarily places toner on the mag roll and gives false impression that it is fixed. Replace toner motors and developer units if I am correct.
banginbishop
06-30-2012, 11:36 PM
reported this a few months ago in my bitchin thread. kyocera TA552ci - told unofficially problems with copy quality going faint but japan cant fix.
