acsolutions
06-08-2012, 03:41 AM
Hello,
I have an error code C-2253 on a Konica C252 which is an issue with the drum drive, I suspect! I walk in with this code shut the door a few time and the machine cycles and comes to ready. I check all the drum units for binding ok then I check the all four colors with the machine grid pattern and noticed the magenta slightly out then I did gradation adjust and after the third on I noticed the yellow and magenta registration were way out. I am wondering if a motor drive the yellow and magenta and another motor drives the black and cyan, I guess that this could be a motor problem or a drive issue. Is there drum drive issues? I know there is no board problem because the problem seems to be intermittent. I think I might be able to pull a motor from a C-250 will this work and if anybody has a part number that would be great! Thanks
