View Full Version : False "set toner cartridge" message on a CS-2550.
itek8301
06-19-2012, 12:10 PM
Cs- 2550 with OEM TK-423 Gives false set toner cartidge message. Remove and reset TD works for a few copies and Message returns. Is there a test for the switch at back of TD holder?
tbsoa
07-02-2012, 10:31 PM
Your machine may need updated engine pwb.
dickierock
07-03-2012, 03:23 PM
Hi there, is this the same as kyocera-mita 2550? If so try fold up a sheet of paper many times into a small square and wedge it between the blue/green toner lever and the toner container at the front of the machine to see if the container has too much room too move away from the switch.Good luck.
itek8301
07-24-2012, 02:12 PM
Replaced toner motor problem solved. Thanks
