View Full Version : Latest firmware for Taskalfa 4550ci
mascara
06-19-2012, 07:36 PM
Please tell me what latest number firmware for TA4550ci and how many tech bulletens for this machine//Thank you
Eric1968
06-19-2012, 07:54 PM
Latest version is 03.00.0070. How many tech bulletins? Well there are a lot, but you won't use all of them.
Venom
06-20-2012, 11:26 AM
The released Version here is 3.06
mascara
06-20-2012, 06:06 PM
I have installed today TA4550. The machine manufactured feb 2012 with firmware 03.00.0077. Is it latest fw? I installed the machine according to Service manual but This machine had insufficient density of the solid fill. This is especially noticeable in the blue. Paper Weight 80 g\m. I did drum and developer refresh. Are there any ways to increase the density of the solid fills, for example as a Xerox Docucolor240, Canon Irc3200?? I would be grateful for any help, as well as for their help with the latest firmware and bulletins for this machine.
Eric1968
06-20-2012, 06:14 PM
Did you do all adjustments in the Service Mode?
U469, U464, U412, U410.
mascara
06-20-2012, 07:11 PM
I have do U464 and U469 from adjustment\maintence, then U410 from service mode... Tomorrow i will try U412бб, If this does not work try to re-install all
Eric1968
06-20-2012, 07:44 PM
Just a thougth : Use a fresh pack of quality paper. Maybe there's too much moisture in the paper or the paper quality is bad.
KYO_OEM
06-21-2012, 10:55 AM
Please try U161/ GRAIN MODE / MODE 1 and execute the U410 again.
Be carefull, with U161 Mode1 or 2 the paperweight for plain paper will be switched to normal 1 automaticlly.
Systemmenue/ common settings / Original_Paper setting/ Mediatype settings / Plain paper must be set to Normal 2 back.
Please try...
