View Full Version : Bizhub C252
pinspin
06-28-2012, 09:01 PM
Please help me to reset to factory default the network interface, thanks
TheOwl
06-29-2012, 02:47 AM
You shouldn't need to Factory reset the machine.
Just change the IP address and so on from the administrator mode.
pinspin
06-29-2012, 05:23 AM
Printer does not print. When I send a print job, the light DATA is not flashing , but ping is correct
goldencup
06-29-2012, 06:06 AM
is the DHCP on or off? how many computers are connected? try to disconnect the machine then ping again, if there is still a reply, there is a conflict with one of your computer.
TheOwl
06-29-2012, 06:13 AM
What port are you using to print to the machine with? RAW, LPR or any other?
Do you have Account Track or User Authentication enabled?
mrwho
06-29-2012, 11:27 AM
If everything else fails, the machine will need to be serviced with the NVRAM reset tool to reset the NIC.
pinspin
07-01-2012, 06:02 PM
for 4
I printed directly from a laptop to check - the copier does not print
pinspin
07-01-2012, 06:07 PM
- account track - disable
- user authentication - disable
- port 9100 , RAW
ck1
07-02-2012, 08:35 AM
you can try clean the system error or change to LPR Print
pinspin
07-02-2012, 06:01 PM
Thanks for help )))
mrwho
07-02-2012, 06:07 PM
Thanks for help )))
So, what was the solution?
