View Full Version : Jamming xi 8020 not pulling original doc
kyogenius
07-01-2012, 08:05 AM
my xi 8020 is not feeding the original when you make a copy, it feeds the original slightly then when the paper roll starts to feed , the original doesnt feed,only started after the client used a blower to bow spilled toner, cleaned original detection sensors no change
johnkon01
07-16-2012, 11:45 AM
check the clutches of the original feeder, otherwise turn the rollers manually and try again. maybe u get an error code from the original feed motor
madas
07-19-2012, 04:44 AM
What are the jam code's? if it is J9000 then check this bulletin.
madas
johnkon01
07-19-2012, 10:46 AM
madas no such codes in xi-8020. it is not fs. it is wide format. jam should be j-005
kyogenius
07-19-2012, 08:07 PM
hi
sure its a wide format machine ,thanks hey,its different to the models on the bulletin
madas
07-20-2012, 01:05 AM
ooppss was in FS mode, as just saw the bulletin before I posted while looking for something else!:o
madas
