View Full Version : Samsung CLP-770ND transfer belt reset
Hi,
I'm installing a new transfer belt for 770ND and need the service mode to reset the counter.
Thanks in advance.
JustManuals
07-09-2012, 04:57 AM
Paul@justmanuals.com
mrizer
07-09-2012, 07:22 PM
To enter the Tech Mode, press “ Menu + Up + Left + OK + Right + Stop + Menu” in sequence, and the LCD briefly displays ‘Tech Mode’, the machine has entered service tech mode.
Although I am quite sure there is no rest for the transfer belt. The new belt will come with a Chip on it that will contain a fresh count.
Thanks.It's been a while since I've worked on this printer.
fr0ntsight
05-14-2013, 07:44 PM
I have one of these units and replaced the entire fuser unit, but it is still saying fuser unit low. I need to reset but can't access the service mode. Does anyone out there know how to access the service mode on this model? The above answers don't work as there is no "stop" button. Thank you!
mrizer
05-14-2013, 08:03 PM
Are you sure you have a CLP-770 and not a 775 or another model? Samsung often changes the sequences.
fr0ntsight
05-14-2013, 09:01 PM
Confirmed it is the 770ND
mrizer
05-14-2013, 09:43 PM
Hmm, not sure why it won't work, but here is that section of the manual: 20725
fr0ntsight
05-14-2013, 11:34 PM
Thanks! that is what I needed.
mrizer
05-14-2013, 11:52 PM
Any time. We have a plethora of manuals and bulletins for all the makes. You can email at mrizer@iteminc.com if you ever need anything else.
Arcadian
12-08-2017, 09:07 PM
Not only that, the belt is the waste toner receptable or has the waste of the toner inside, once it fills up you start having squeaking coming from the belt as well, if it says to change it then do so, its a bit costly, best place is to look on ebay, you might get lucky.
Good luck
Arcadian
